Whenever I load a cd track onto the non-active deck or save a track to MP3, the playback of the active deck slows down, the sound quality degrades and often I get a digitized distortion. I have p4 1.6ghz and 512mb ram
Posted Mon 11 Oct 04 @ 4:21 am
The track is analysed as it is coppeyd off the cd and this can lead to an overload on system rescources causing there to be insuficient performance to properly play back a song on the other desk. Changing the thread/process priority of virtualdj.exe in task manager helps on some systems i have used.
Posted Sun 17 Oct 04 @ 3:04 am
check to see if your Soundcard and IDE ports are sharing an IRQ
Posted Sun 17 Oct 04 @ 3:32 am
a CPU overload would result as a one second "loop" in the playback, not as distorded sound.
So I think this is an hardware issue.
Try to change your IRQs.
Posted Thu 21 Oct 04 @ 4:41 pm
