Forum: Old versions
Topic: maya44 usb static sound on VDJ4.2
cocoi10Home userMember since 2005
recently bought maya44usb. it runs perfect but has this static like popping sound while using VDj v4.2 . When i use the maya44 in other programs like sonique or WMP it sounds perfect. what could be causing this static sound when im using VDJ??
Posted Tue 31 Jul 07 @ 2:11 pm
sbangsPRO InfinityMember since 2004
what is your system spec?
Posted Tue 31 Jul 07 @ 5:57 pm
I got the same problem with the Maya44 usb..
Details on my laptop:
* Dell Studio 1535 (Inspiron 1535)
* 4GB RAM, DDR2, 667MHz 2 Dimm
* Intel Core 2 Duo T8100, 2.1GHz, 800Mhz, 3M L2 Cache
* ATI MOBILITY RADEON HD 3450
* 320G, 5400 rpm SATA Hard Drive (Western Digital, WDC WD3200BEVT-75ZCT1)
* Microsoft Windows Vista SP1 Home Premium Edition (32-bit)
Posted Sun 08 Feb 09 @ 5:15 am
jimmy bPRO InfinityMember since 2007
Firstly I would suggest downloading and trying the latest demo.
If you using the Maya44 in Asio mode, try backing off on your Asio buffer, set it to fast or normal and see what you get.
Posted Sun 08 Feb 09 @ 5:33 am
i had the same exact problem my solution was turning down the gain because it picks up small vibrations from the sound card if the gain is too high just mess around with is for a while. mine got so bad that it was skipping tracks forward and backward.
Posted Wed 11 Feb 09 @ 3:28 pm
I tried that and mines still sounds like its underwater or garbly. Any help with this??
Posted Mon 23 Mar 09 @ 12:00 pm
any solution to the static crackle noise? I have the same problem.
Posted Tue 28 Apr 09 @ 10:14 pm
Bro you probably also need to add a ground adapter to your laptop. That is normally an orange adapter that only has two electrical prongs instead of 3 like your laptop. This will ground your sound and help stop static also.
Posted Tue 28 Apr 09 @ 10:57 pm
I would like to inquire if anybody has had success with virtual dj and stanton c314 turntables. my issue is the cue's that I set in virtual are not being accessed with the turntables. please inform. I love both products and dying for these two to work together. Thanks in Advance
Posted Tue 28 Apr 09 @ 10:59 pm
Also uncheck the safe mode in options
Posted Wed 29 Apr 09 @ 11:45 am
