Forum: Old versions
Topic: Lexicon Lambda USB Audio Interface compatible with VT & bc200?
Is Lexicon Lambda USB Audio Interface compatible with Virtual DJ & bc2000? It will not be an issue to use bc2000 just as a controller. Thank you in advance for your help!
Posted Wed 21 Mar 07 @ 11:40 am
If you install the soundcard properly vdj will recognize it and yes, you can use bcd2000 as pure midi controller and to choose your usb card as main out, just check if it works in 4.1 mode for getting the prelisten of both decks from the same card,regards.
