Guys,
I'm going nuts here. I had Virtual DJ and Hercules installed on my laptop which had Windows XP Professional installed on it and it worked great. I bought a new laptop with Vista installed. I tried installing the drivers for Hercules on it and it didn't recognize it. If I go to Start/Control Panel/Programs and try to uninstall Hercules Drivers, it says to unplug Hercules and replug and it just sits there. It won't uninstall and let me put on the recent updates Hercules came out with. Any help would be greatly appreciated.
I am running Virtual DJ as well (the version that came with the controller.)
Posted Wed 14 Mar 07 @ 3:34 am
Heya
grab the vista driver here
https://virtualdj.com/forums/66083/Hardware_Technical_Support/Common_Device_Drivers___.html
however to use the console you A need to wait for the vista console edition
comming very soon
or B buy pro
as it is currently supported under it.
Regards
Simon
comming very soon
or B buy pro
Regards
Simon
Posted Wed 14 Mar 07 @ 12:21 pm
