Can someone help me out?
Can you explain to me what is happening when i select the beatgrid effect?
When a bar on the visualisation is selected/deselected what does that mean?
Why are there four rows and four columns?
etc
sorry if i am being stupid but i a beginner
thanks in advance!
etc
thanks in advance!
Posted Thu 08 Mar 07 @ 2:09 pm
it makes beats
the rows and colluns are for choosing the pattern of the beats
it works similar to a drum machine. it follows the grids pattern
when you start the plugin you get one 4 beat loop.
unless you choose one of the repeat options on the right for a longer loop.
Posted Thu 08 Mar 07 @ 9:22 pm
Hi,
It's difficult to explain really, but it basically re-arranges the rhythm of the song. If you highlight all the top row of squares you will get the first beat after you activate the effect played 16 times very fast.
If you selected all of the squares in the second row, you'd get the second beat after you activate the effect repeated 16 times very fast.
Neither of these will sound very interesting I would guess, so just make a random pattern (it will only let you highlight one square in each colum) and see what it sounds like.
You can easily save a pattern that you like using the red buttons down the right hand side of the screen.
Good luck!
Good luck!
Posted Tue 27 Mar 07 @ 4:07 am
Love using it!!!
Posted Thu 29 Mar 07 @ 9:13 pm
robertsr wrote :
Love using it!!!
Yes, the best way to know how it works, and sure you'll love this effect.
Posted Fri 30 Mar 07 @ 10:49 am
Ya bet sooo! Beatgrid rulezzzz =D When songs r about to "explode" or when they have a similar beat through all the music, using BeatGrid realy makes the difference ;)
Keep on Scratching \m/
High Regards, Bart.
High Regards, Bart.
Posted Fri 06 Apr 07 @ 10:13 pm
On the bottom right, there are 3 buttons, what does the middle button do?
Posted Mon 16 Apr 07 @ 1:20 am
the middle ones when u activate the beat grid it will move u back from where u pressed it.. in other werds it make a looping for u..
Posted Wed 18 Apr 07 @ 9:06 pm
I love beatgrid too but I can find the effects anymore using the Macversion. Is it not available for macusers?
Posted Fri 20 Apr 07 @ 10:49 am
it`s good.............and very cool))) I`m from Russia.......
Posted Mon 30 Apr 07 @ 12:58 pm
Can somebody post a picture of a good beatgrid that wil work on many song. i REALLY want to use it.
Posted Fri 30 Jan 09 @ 12:21 pm
it makes beats
Posted Tue 03 Feb 09 @ 2:01 pm
@eliasu, Pls do not spam the forum. thanks;)
Posted Tue 03 Feb 09 @ 4:43 pm
can someone pleaze give me a link to download this beat grid :(
im really in crisis over here !!!!
Posted Mon 30 Mar 09 @ 3:09 pm
You need to purchase VDJ from this site and the beatgrid will be there with it;)
Or give the trial a go and it work fully for 20 days.
http://www.virtualdj.com/download/trial.html
Hope to see u with us soon as a pro user;)
Posted Mon 30 Mar 09 @ 5:37 pm
I have the same problem ! It used to work but not anymore !
Posted Sat 04 Jul 09 @ 10:14 pm
There is beatgrid for mac all along and it been working for the past version;)
You need to register in your modify your profile page and get the updates.
What version do you use?
Anyway hope to see you with us soon as a pro user;)
Posted Tue 07 Jul 09 @ 1:37 am
Can someone please explain how to reset beatgrid to its original pattern. I switched it up, but I would like the original grid but cannot find out a way to restore it. thank you
Posted Thu 14 Jan 10 @ 12:50 am
Beatgrid can be fun. Though using it too often dose become a bit boring.
Posted Fri 15 Jan 10 @ 1:47 pm
I love this effects soooooooooooo Much,It Makes Sound Really Great as if you are the BOSS
How do i get the Ras Horn Effcts or Plugin into VDJ
Cuz I only found the Ras Horn Only in the Numark Cue.How do i get the Rass horn Plugin
Posted Mon 18 Jan 10 @ 3:39 pm
