Forum: Old versions
Topic: Timecoded vinyl help?
I have 2 soundcards connected to my pc 1 is an onboard 7.1 sound card and the other is a creative audigy 2zs both have 1 input. can i use these togather with the timecoded vinyl
Posted Tue 13 Feb 07 @ 7:28 pm
listen2PRO InfinityMember since 2005
You should be able to but some cards work better then others. You will need to download ASIO4ALL, a small ASIO emulator to get the cards to work properly.
Posted Tue 13 Feb 07 @ 9:25 pm
Will asio4all work definatly ? what settings will asio4all need because i have asio4 all and it tells me what settings the cards have, what is good in these terms
Posted Wed 14 Feb 07 @ 2:02 am
sbangsPRO InfinityMember since 2004
does it say beyond logic?
Posted Wed 14 Feb 07 @ 2:08 am
no its green and running
Posted Wed 14 Feb 07 @ 2:23 am
