Topic: Help!! Using Pioneer CDJ-800 CD Decks
I am interested in getting Virtual DJ, I have 2 Pioneer CDJ-800 CD Decks and a Numark DXM-09 Mixer, my question is would I be able to use my decks as the controllers for the Virtual DJ program? And what would be the best ASIO compliant sound card for that set up? I would be running off Windows.
Thanks in advance.
DJ Triple H _ Chicago, IL.
Posted Mon 05 Feb 07 @ 9:16 pm
Yes, you can use cdj800s to control VDJ flawlessly, just as if you had real cds playing... + the extra features the software gives you on top of that;)
I use cdj800s all the time...
You need a timecode cd for that, and its totally free for download from this website ;)
Burn it as audio cd, and you are ready to rock..
There are plenty of good asio soundcards, depending on what connection you wanna use
USB card that work good :
- Maya44 usb
- U46DJ
- Edirol UA-1000
and more
Firewire cards that work good:
- Prosonious Firebox
- Shaffire Le
- Edirol FA-66 , FA-101 and more
- Digidesign Digi 002 Rack
- Ego-Sys QuataFire 610
- Hercules 16/12 FW
- M-Audio FireWire 1814
- Terratec Phase 88 Rack FW
and more
PCI cards that works good :
- Delta 44 & 66, Delta 1010LT & 1010
- Soundblater X-FI platinum or elite
- Mayy 44 PCI
- Maya 1010
- Sound Blaster Audigy 2 ZS Platinium Pro
- Sound Blaster Audigy 4 Pro
- Echo Layla 3G
- Ego-Sys ESP1010
- Ego-Sys WaveTerminal 192M
- Soundblaster E-MU 1820, 1820M
- Marian Marc 4 MIDI
and lots more
PCMCIA cards that works good
- Soundblaster E-MU 1616M
- RME Audio Hammerfall DSP System
Generally speaking, almost any card that has two line ins in STEREO, and two line outs, will work, and has ASIO drivers its likely to work (with low latency drivers).
Those listed above are PRO cards, so some are damn expensive..
But get a card thats not the most expensive, but not the cheapest eather.
