My SA3 mixer has two sets of master out:
2 (1/4") Balanced/ (RCA) unbalanced,
+4 dBu balanced / -10 dBV unbalanced
(see pic here http://i5.tinypic.com/2a6m834.jpg)
I usually use the RCA output as my main output line (goes directly to the amp). my question is, can i use the 2 (1/4") Balanced output as my main output line instead? what i am trying to do is free up the rca output so i could use that as my recording output to record my mix.
On another note, what is balanced and unbalanced output? whats the difference between the two?
Pls advice if this is doable.
Posted Sat 03 Feb 07 @ 4:02 pm
should be fine
check this for more info
http://home.btconnect.com/woodgreen/tech_tips/techtip/art6.htm
Posted Sat 03 Feb 07 @ 4:17 pm
thanks skyfxl. so would this converter do the trick?
Posted Sat 03 Feb 07 @ 4:29 pm
yes should be fine :)
Posted Sat 03 Feb 07 @ 4:32 pm
thanks man. im gonna get a pair tomorrow.
Posted Sat 03 Feb 07 @ 4:36 pm
i use those when i have to but much better to get the proper cables......get rca on one end terminating in 1/4" on the other ...much better levels....anytime possible get the proper cable instead of converting
Posted Sat 03 Feb 07 @ 6:44 pm
