I have ADS Technologies USB 2.0/FireWire Desktop Adapter will this with with my djx700 mixer and also work with my virtual dj?
Posted Wed 17 Jan 07 @ 8:45 am
also with ADS Technologies USB 2.0/FireWire Desktop Adapter if anyone know what cables i need to buy? IM NEW AT THIS.
Posted Wed 17 Jan 07 @ 8:46 am
you need a soundcard 4.1 +
and virtual dj pro
what you mentioned is a usb to firewire card to my understanding
and virtual dj pro
Posted Wed 17 Jan 07 @ 11:09 am
I got Virtual Dj ver.3 does it matter if i get the pro?
Posted Wed 17 Jan 07 @ 6:08 pm
Dear itznoodle
Virtual DJ 3.0 has not been available for a long time indeed,
It lacks many of the features we now take for granted and love :)
be aware that cracked copies have a very nasty bug , caused by the crack which will after about 2 hours will cause loud static and can lead to possible damage to speakers ,
So please get the latest demo 4.2
http://www.virtualdj.com/download.html
And benefit from the new releases features :)
and if you like this program and , or would like to expand with adons
please support its development by purchasing it ,
Kindest Regards
Simon
Kindest Regards
Simon
Posted Wed 17 Jan 07 @ 6:18 pm
OKay so i went out and buy the sound card with two stereo output now what cable do i need for my djx700 mixer?
Posted Wed 17 Jan 07 @ 7:07 pm
you might not notice it for short periods or on a home system , but in a club and it happens owch manager will kill u
Posted Wed 17 Jan 07 @ 7:10 pm
You probably need mini-jack to phono... mini-jack into soundcard, and phono into mixer (line in).
What you need at the soundcard end depends on your soundcard though...
Posted Wed 17 Jan 07 @ 7:41 pm
okay so with two output i need two mini-jacks?
Posted Wed 17 Jan 07 @ 8:20 pm
yes;)
Two of the cables above, into your two outputs at soundcard, and the two (pair of) phonos into line in at two channels at your mixer...
Hope that helps, and hope to see you as a full member soon, if you like the software ;)
Posted Wed 17 Jan 07 @ 8:45 pm
i do like the vdj its easy and fun to use....is it true that independent stereo channels on a sound blaster sound card would not work the an external mixer? or just any two output soundcard would work?
Posted Wed 17 Jan 07 @ 8:56 pm
any two output card will work ;)
from cheap usb surround cards, to proffesional cards..
Better cards give better dynamics/sound, so dont go for the too cheap cards, but the mid range give nice sound.
And soundblaster have some very good cards too, all from cheap to real good ones..
Posted Wed 17 Jan 07 @ 9:02 pm
thanks alot that help me i was so confused. so all i need is the sound card and mini jacks?
Posted Wed 17 Jan 07 @ 9:17 pm
yes:)
Well most have mini jacks.
Check the soundcard you get. Some have phono outs.
Posted Wed 17 Jan 07 @ 9:58 pm
can i also plug in my turntable and work with the VDJ and do i need VDJ Timecoded Vinal ?
Posted Wed 17 Jan 07 @ 11:16 pm
You need timecode vinyl's, just buy them...only $50 a pair.
Posted Wed 17 Jan 07 @ 11:19 pm
yes, you would need timecode vinyls if you want to control VDJ with turntables
Posted Wed 17 Jan 07 @ 11:22 pm
