Topic: Small Problem With BeatMatch.
SeanehHome userMember since 2006
Hey just a small.. Well slight problem!
I've had the Hercules since christmas but Im familiour with VDJ anyway.
But yeh.. when i put a song into onto the 'Deck' on screen, it automatically brings the pitch control [on screen] to a point with the same number of beats as the other song on the other deck.
Can i change this so even if it isn't the right beat that it wont change?
Hopefully you understand me haha!
Thanks
Sean
Posted Fri 12 Jan 07 @ 7:24 pm
cstollPRO InfinityMember since 2004
In config - options tab turn off (Disable) the Auto Pitch Match and turn on (Enable) Auto Pitch Reset
Posted Fri 12 Jan 07 @ 7:49 pm
Thanks
Fixed :D lol.
Posted Fri 12 Jan 07 @ 7:59 pm
