I've been using the Gigaport AG USB sound card for awhile now, but I've been having issues with channels dropping etc. and amd looking to switch to a more stable card for my laptop. I don't have a standard network card slot, so an Indigo DJ will not work (unfortunately) I need one that will split the audio into two channels to run into an external mixer. What is the "preferred" card to use with VDJ?
Posted Wed 10 Jan 07 @ 4:49 am
the u46dj is the most popular here , its not going to be made much longer unfortunately
aslo users have had sucess with the presounous firebox
Virtual Vinyl is aslo not far off now :)
the giga port is usualy a stable card from what i have read are you sure you dont have a possible conflict with another device ? sounds possible.
use my blog here to check it out https://virtualdj.com/blog/skyfxl/blog3753.html
Regards Simon
Regards Simon
Posted Wed 10 Jan 07 @ 1:30 pm
