Welcome to the guide in which we shall discuss
how to behave on a forum ;)
The do's
The don'ts
Thanks for reading this
and remember to try and stay cool calm and collected, and most of all enjoy yourself and learn :)
The do's
- Have fun ;)
- Remain polite at all times
- Remain on topic , if the thread you are reading is not about the topic you wish to talk about look for one which is; if there isn't, make a new topic
- Help others if you can :)
- Stay calm, we can help you with your problems
- Be specific when reporting an issue or problem
- Check if there is already a thread about your issue and a fix (use the forum search system)
- Ensure you have read all of the sites weblinks before asking about them :)
The don'ts
- Do not abuse others
- Do not WRITE IN ALL CAPS because it sounds like you are shouting at people :(
- Do not abuse folks who try to help you they are just other users after all and want the best for you
- Do not make multiple posts of the same problem it confuses matters and actualy reduces the chance of you getting good support
- Do not get into arguments, it is not very professional
- Do not ask for downloads which are above your level
- If you cracked the software and it does not work please do not get abusive about it , what did you expect...
- Do not attempt to post spam , like hi hi hi (1.you look stupid 2. you will loose your acount)
 some tips :)
- Do not post your email on the forum , you will be asked for downloads by crack users!, put it on your blog where you can choose the level at which users can see it ie home +
 (noticed you have posted your email by mistake contact a teamer or mod)
- if your problem relates to payment of the software, protection error or a lost serial go here:
 http://www.virtualdj.com/contact/
Posted Thu 28 Dec 06 @ 6:08 pm
