Forum: Old versions
Topic: Fader start in 4.2 - Page: 1
foamgodPRO InfinityMember since 2004
Anyone having any problems with the Fader start effect? I have the latest version of the plugin and it doesn't appear anywhere in the effects. I liked using it in the past as it was very practical.
Posted Thu 28 Dec 06 @ 1:09 am
sbangsPRO InfinityMember since 2004
check if it is in the sound fx folder in the virtual dj program folder
Posted Thu 28 Dec 06 @ 1:10 am
What's the name of the effect, I haven't seen it in the plugin download place?
Did I miss something (obviously did)?
Posted Thu 28 Dec 06 @ 8:07 am
i belive its callled fader start
Posted Thu 28 Dec 06 @ 1:20 pm
Yup, ok, I got it. But even after reading about it,
I'm still not sure exactly what it does?
What is it intended to do; in simple terms?
Posted Thu 28 Dec 06 @ 10:33 pm
fader start
means that the music doesnt start until you move the fader like on cd mixers :)
say i move the fader to deck B , it starts
A stops
Posted Thu 28 Dec 06 @ 10:39 pm
It is in the sound effects, but doesn't show any on or off capabilities , parameters, or any way to activate/unactivate it?
What may be the problem, here?
Posted Fri 29 Dec 06 @ 7:59 am
djcelPRO InfinityModeratorMember since 2004
Do you use Windows XP Sp2?
I have just verified: FaderStart still works with VirtualDJ v4.2r1
Posted Fri 29 Dec 06 @ 8:10 am
Yes. Service pack 2 is installed, should it be or should it NOT be.
You were not very clear as to which?
Posted Fri 29 Dec 06 @ 8:59 am
Posted Fri 29 Dec 06 @ 8:47 pm
Mine still doesnt work. Why is that?
Posted Fri 29 Dec 06 @ 9:20 pm
mainedjPRO InfinityMember since 2006
I just d/led it, and it shows up in the window where you select the effect, but when you select it, it go to the brake effect instead. :(
Posted Sat 30 Dec 06 @ 5:06 pm
i will compile the dll again in one week with my old computer.
Posted Sat 30 Dec 06 @ 5:36 pm
actually, it pauses instead of stopping the song ;then it restarts the song where it left off @ instead of @ the beginning
Posted Mon 01 Jan 07 @ 12:22 am
In my case, it shows up in the effects, but doesn't actually show any means of being able to activate or make any adjustments of any kind whatsoever.
Excellent effect otherwise, though - I've used it to good effect in many of my mixes.
Posted Mon 01 Jan 07 @ 6:32 pm
Change the option on deck 1 and 2 with sliders: select "stop" instead of "pause"
Posted Tue 02 Jan 07 @ 11:39 pm
@ dj cel... that should do it;
I only loaded the plug in to test for foamgod;I personally have fader start on my external mixer (on the crossfader and on the line sliders =-P
Posted Wed 03 Jan 07 @ 4:23 am
Hi guys
Just want to now how to leave it on full time...when you load a new song it deactivates the Fader start and you have to turn it back on
Later DJ MikeD
Posted Wed 03 Jan 07 @ 4:47 am
Posted Wed 03 Jan 07 @ 12:10 pm
Thanks Man I will give that a trY
Sky you are quick to answer..
Later
DJ MikeD
Posted Wed 03 Jan 07 @ 7:15 pm
87%
