Forum: Old versions
Topic: Very small line between 0% and 100% timecode quality
djzeroPRO InfinityMember since 2003
if you are having problems with 0% time code quality you need to boost the gain substantially in your soundcards config pannel. (if using turntables you can also put some more weight on the stylus) but first try and do it via software. my graph looks as if the green lines a dlightly cliping inorder to get 100% timecode. and it is only a tine volume change to go back down to 0%
Posted Wed 04 Aug 04 @ 2:19 am
Posted Wed 04 Aug 04 @ 7:27 pm
