Hi guys i am almost setup here..... got rid of the humming/buzzing sound by muting the Monitor buttons on the u46dj.
Now i cant get my regular vinyl to play through VDJ. i set numbers 1 and 2 buttons to activate deck under keyboard controls. i put on the regular vinyl Hit the 1 Key and..... Silence?????
i use the RIP VINYL feature and i have to use the USB 3- USB 4 under inputs.... but i hear the regular vinyl fine!!!
WTF is going on???
WTF is going on???
Posted Tue 12 Dec 06 @ 5:21 am
remember for full use of this
you will need pro ;)
http://www.virtualdj.com/products/comparison.html
Posted Tue 12 Dec 06 @ 10:31 am
could you post your sound config as a screenshot
Posted Tue 12 Dec 06 @ 10:37 am
ok ill try to get a screen shot tonight.
again..... i am no longer using the Mk2. THIS is on the trial version.
Posted Tue 12 Dec 06 @ 5:20 pm
sorry could not get a screenshot.. i dont have a picture editor on my computer.
BUt i unmuted the monitor channels on the u46dj and now can hear regular vinyl, its just that the humming noise is now back!!
also it seems changing back and forth from regular vinyl to TCV makes the program crash (well not the whole program ) but the hotkey to switch back and forth
Posted Wed 13 Dec 06 @ 4:36 am
to take a screenshot press Shift and Printscreen on ur keyboard then go to paint
and press paste
then upload the image onto tinypic.com and they will provide a link
and press paste
Posted Wed 13 Dec 06 @ 10:25 am
