I have: denon DN-D9000 cd player and Denon DN-X900 mixer
i want to use my denon what do i need to do? please
i have the hercules mk2 and virtual dj.
Posted Fri 08 Dec 06 @ 8:11 pm
Posted Fri 08 Dec 06 @ 8:31 pm
you need virtual dj pro
burn two copies of this to audio cd
http://www.virtualdj.com/products/timecode/VDJTimeCode.mp3
hook your decks up like this
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
goodluck
goodluck
Posted Fri 08 Dec 06 @ 8:32 pm
thanks, but a have the home edition
Posted Fri 08 Dec 06 @ 8:59 pm
as i say u need to upgrade...
Posted Fri 08 Dec 06 @ 9:09 pm
Some additional info:
You could attach your cd player to your mk2. You could also try it, but the time code will stop after 5 minutes. This is a limitation of the Hercules version. See [url=http://www.virtualdj.com/products/djcedition.html]here[url] for more info.
Ewout
Ewout
Posted Sun 10 Dec 06 @ 7:18 pm
like that ;)
Posted Sun 10 Dec 06 @ 7:19 pm
so all i need to do is burn that timecode on a cd, put it inside my denon dn-s1000,and open virtual dj 4?
Posted Wed 31 Jan 07 @ 1:34 am
I guess there is something to be said about Clairty.
Your software that come with the hercules WILL NOT support timecoded for more than 5 min.
It is a "LIMITED SOFTWARE EDITION" basically given as a gift.
To use timecodes you need to UPGRADE TO PRO.
otherwise
YOU WILL BE FRUSTRATED.
otherwise
Posted Wed 31 Jan 07 @ 3:02 am
