Gentlemen:
Still trying to understand how I am going to hook up my set up. Will I go from my sound card to each channel of my mixer? So I need a two channel sound card?
Are there any excellent internal sound cards or should I just get an external? If I get an external don't I have to disable the on already in my laptop?
Would my set up run... computer to sound card via usb, then sound card to channels one and two on my mixer? The DAC 3 would just connect usb to my computer?
Sorry for the annoying basic questions.. I just want to have all the hardware before I get the software.
Thanks. CM
Thanks. CM
Posted Fri 08 Dec 06 @ 3:14 pm
yes a 4.1 or 7.1 card is needed
dac just plugs in and you enable it on remote control
Posted Fri 08 Dec 06 @ 7:01 pm
you don't have to disable the one already in ure comp- vdj will give u the option to chose which one(s) you want to use.
the DAC 3 config is correct how you said.... (assuming u were to go external soundcard) the soundcard would go into USB and then the dac 3 would also go usb
if you're going internal, go with sky and do 4.1 or 7.1 or just get a two channel external usb!
Posted Fri 08 Dec 06 @ 9:45 pm
