Sup all, I was using VDJ this moring, took a nap and when use it again to record some remixes and then tried to download songs from my HD. I keep getting that lovely Fatal Crash message with the smiley face. I ty to recover from it and nothing. I get an error message of R6025. Any ideas?
MS
MS
Posted Sat 25 Nov 06 @ 5:09 pm
You tried restarting your Pc? and see if it happens again
Posted Sat 25 Nov 06 @ 5:13 pm
Yes I also reinstalled VDJ and nothing yet...:(
MS
MS
Posted Sat 25 Nov 06 @ 5:14 pm
got xp?
Posted Sat 25 Nov 06 @ 5:15 pm
Yes I do and I am using VDJ 3.4 still.
MS
MS
Posted Sat 25 Nov 06 @ 5:16 pm
go to startmenu
programs
acessories
system tools
pick system restore
choose a date about 2 days ago
and this will restore the settings of your system to this time , i think this could solve this for you
another thing to try would be to upgrade to v4
programs
acessories
system tools
pick system restore
Posted Sat 25 Nov 06 @ 5:21 pm
I will try this Sky. Thanks. BTW congrads on the VIP status. Also I don't care much for V4 due to the Effects usage. I perfer V3.4 Effects engine alot better.
MS
MS
Posted Sat 25 Nov 06 @ 5:24 pm
goodluck , thanks :)
i kinda agree with the fx thing but the new one has its merits aslo :)
Posted Sat 25 Nov 06 @ 5:26 pm
I'm back and still doing the same thing. Anyother suggestions?
MS
MS
Posted Sat 25 Nov 06 @ 5:32 pm
Delete your registry entries for VDj then reinstall
Start----Run "type in the box" "Regedit"
Since your using only 3.4 the entries should be under
HKEY_LOCAL_MACHINE / Software
find the whole VirtualDj folder right click and delete it you can also check for entries in the HKEY_CURRENT_USER / Software
Posted Sat 25 Nov 06 @ 5:33 pm
I will give it a shot.
MS
MS
Posted Sat 25 Nov 06 @ 5:34 pm
cool
becareful mistakes will crash ur pc bigtime
Posted Sat 25 Nov 06 @ 5:44 pm
Tried it and still the same thing. :(
MS
MS
Posted Sat 25 Nov 06 @ 5:47 pm
The Support Team should have a list of error codes, so they can get it up for you quickly or know right away what it is causing it
Posted Sat 25 Nov 06 @ 5:49 pm
Thanks guys.
MS
MS
Posted Sat 25 Nov 06 @ 5:51 pm
PC + lake + strong arm = problem sorted... for the meantime :D
Jokes, but i wonder why it gives a cheeky smiley face??
Posted Sat 25 Nov 06 @ 5:52 pm
Lol , Good point maybe it should be changed to an aggrevated face
Posted Sat 25 Nov 06 @ 5:59 pm
Well it seems that it's a Windows Xp error not a VirtualDj error, just google windows xp error r6025
Posted Sat 25 Nov 06 @ 7:10 pm
dont suppose you have aol software on your pc , that aparently can cause it
Posted Sat 25 Nov 06 @ 7:20 pm
try to dissable some of the programs that start during the boot
start -> run-> type msconfig and go to the startupfolder,dissable all,then go to services and check hide all microsoft services, disssable all services that you don“t need,apply and reebot your computer...most of the microsoft errors has to do with startup processes
I did a googel on the error and it says that it can be caused by some java based applications & other visual bacis c++ shit sfuff
Posted Sat 25 Nov 06 @ 7:24 pm
