Forum: Old versions
Topic: Noise when searching on the incoming track....
kinnisHome userMember since 2006
Hi all,
got a little weird noise when i manually rewind back the deck that i am going to mix in.
sounds like a slowish vinyl type noise ( forgive my description, useless at the best of times hah )
anyone else have this problem ? or do they have a solution ? possibly my soundcard ?
cheers
Posted Thu 09 Nov 06 @ 5:31 pm
sbangsPRO InfinityMember since 2004
thats the vinyl noise lol ........
its simulating slowy rewinding decks
Posted Thu 09 Nov 06 @ 5:35 pm
hehe nah, sorry should of made a bit clearer ( told u im no good at descriptions lol )
its heard when i record my mix ( can hear the other deck when the cross fader is fully over to the current playing deck )
if that makes sense lol :S
Posted Thu 09 Nov 06 @ 6:04 pm
what soundcard are you using
what config?
Posted Thu 09 Nov 06 @ 6:18 pm
Hi there,
im using : C-Media c3dx cmi8738 PCI
its a 5.1 soundcard.
not sure what you mean by config ?
maybe the output settings in vdj ? if so then i have it set to speakers and a headphone out.
Posted Mon 13 Nov 06 @ 5:59 pm
would it be possible to post a link to a sample of the recording here?
Posted Mon 13 Nov 06 @ 9:46 pm
<a href="http://www.filelodge.com/files/room17/426707/test.mp3">test.mp3</a>
sorry for the genre of music i used lol
Posted Tue 21 Nov 06 @ 2:03 am
Posted Tue 21 Nov 06 @ 2:04 am
are you doing a direct record using the onboard mixer or an external mixer? some external mixers suffer from fader bleed....eveb though the fadwr is over to the other channel or all the way off, the sound still bleeds through.
Posted Tue 21 Nov 06 @ 3:38 am
nah dont have external.
happens when i twiddle with and of the fader,high mid low controls....
Posted Fri 24 Nov 06 @ 4:23 am
then its possible that you are putting to much low eq onto the tracks using the eq knobs try a lower eq
aslo watch high eq as this can distort music aslo
Posted Fri 24 Nov 06 @ 10:51 am
nah wouldnt be that, as it happens when any of volume knobs or faders are moved.
the low mid high controls are all set to the middle ( green )
Posted Fri 24 Nov 06 @ 7:55 pm
maybe then your putting the volume up to much and its distoring
Posted Fri 24 Nov 06 @ 8:14 pm
nothing to do with the volume dont think. It is that you can hear the noise on the current playing track , when i am altering low high mid on the track i want to cue ( also when i manually search thru the track i want to cue ).
Posted Fri 24 Nov 06 @ 11:06 pm
do you have the crossfader right across?
i miss read your post sorry
could you post your soundconfig
here
as a picture using
www.tinypic.com
aslo are you recording from master?
Posted Fri 24 Nov 06 @ 11:08 pm
