BCD2000 WDM (directX) MODE GUIDE
This is for those who dont need to run in asio (asio is first of all for timecode vinyl input users)
Also a good solution for those who run into Asio driver errors...
Thanx to Manquin for pictures!!
![](http://i9.tinypic.com/2dvq054.jpg)
![](http://img84.imageshack.us/img84/7826/2xi3.jpg)
![](http://img217.imageshack.us/img217/8237/3sn8.jpg)
Posted Sat 14 Oct 06 @ 5:18 pm
BCD2000 MIDI CONTROLLER MAPPING
You can use the controller as a midi controller only (with or without the BCD2000 as soundcard)
For mapping the midi controller part, you can do so manually by adding the enclosed XML mapper file, that will set up MIDI shortcuts in VDJ. (You can change the XML code too, for your own likings)
NOTE:
- in this mode, led's on console will probably not work, or work right.
A "hardcode" mapper will come soon, made by DJ Cel, that will allow mapping of buttons of the BCD2000 on the fly while you mix. This kind of mapper will work just as the default native support, including led and more (like Hercules mappers). It will be released later...
MIDI SETUP
![](http://img104.imageshack.us/img104/5525/4ux4.jpg)
![](http://img84.imageshack.us/img84/4024/5pf2.jpg)
![](http://img217.imageshack.us/img217/7108/6bj4.jpg)
Posted Sat 14 Oct 06 @ 5:44 pm
