Topic: I need Audio on my VID MIX'Z...Help!!!
Hey guys,
I have a small issue with my new venture. When I record my vidz using VDJ 4.0/Hercules MK2/FRAPS, I only get the video with NO sound. How can fix this as the MK2 is the default sound card presently. Is it because the USD connectivity??? HELP!!!
Posted Sun 08 Oct 06 @ 7:56 am
make sure u check the record sound box in the movie tab;check the "detect best sound input" if that dont work try "use windows input" .. detect best sound should be the right choice though .
good luck
Posted Sun 08 Oct 06 @ 2:36 pm
Hey, I ran some a few "lab" tests and guess what I discovered, the Hercules which is a MIDI-USB Soundcard doesnt allow me to record Audio outside of Virtual DJ---strange, isnt it, however when I default to my Audigy Soundcard, the application Fraps records both Video and Audio.
Even upon opening Sound Forge 8.0, it doesnt see the Hercules Card, all I see is windows mapper, the BIG question now is, "CAN RECORD AUDIO FROM A USB SOUNDCARD ???"
Posted Tue 10 Oct 06 @ 4:53 pm
ANYONE ???
Posted Wed 11 Oct 06 @ 4:29 pm
