Forum: Old versions
Topic: DAK 3 won't work... Help
I just recieved the Dak 3 from PCDJ and when I try to get it to work with Virtual DJ 4.0 iand t does not. When I go into the configure screen, I do not see an option to get it to work. The instruction booklet that comes with the DAK 3 only tells you how to plug in the USB cord. Can some one help me?
Posted Sat 16 Sep 06 @ 1:14 am
phillydjPRO InfinityModeratorMember since 2004
did u enable it in you remote control settings?
Posted Sat 16 Sep 06 @ 1:52 am
Thank you for the help. I looked and it worked. i just got it in and was too excited to use it and overlooked that option.
Thanks again
Posted Sat 16 Sep 06 @ 9:13 am
