Since I use a samples a lot when doing my gigs, I think itz onus of me to purchase an external module which allows me to assign the "F1-F12" keys to it. I heard of the Boss 202 and 303 Sampler but I think they are lacking USB2.0 connectivity, however can you Pro-DJz out there recommend a proper hardware for me ....THNX A MILL!!!!
Posted Mon 11 Sep 06 @ 6:02 pm
![](http://www.moogaudio.com/store/prodimages/evolution/uc33-b.jpg)
UC-33
9 sliders with autostart for sampler ..
+ 24 knobs
and preinstalled presets with VDJ ;)
Posted Mon 11 Sep 06 @ 6:09 pm
Does it have RCA output if I wanted to run it through my external mixer ???
Posted Mon 11 Sep 06 @ 6:20 pm
It does not have rca outputs, while it is only a midi controller and has not a sound card builtin. You could use for example an Esi u46dj. This card has 6 (mono) outputs: 2 for deck 1, 2 for deck b and you could assign the other 2 for samples. Just a note, this was possible in vdj3.4, but currently not in vdj4. When the advanced sound card option is implemented again (4.1?) this could also work in v4.
Ewout
Ewout
Posted Mon 11 Sep 06 @ 10:46 pm
Hi,
I havn't got a u46DJ card, so i'm not sure, but i thought i heard somewhere yo could set it up like that in VDJ 4 by using the "3-lines mixer" soundcard option.
Posted Tue 12 Sep 06 @ 1:11 pm
Any other suggestions DJ's, I need a sampler with both USB and RCA ports...!!!
Posted Tue 12 Sep 06 @ 4:34 pm
