Topic: Recording a CD and GOOD CD Ripper for Audio???
Is there a way of making a list of songs in Virtual DJ and Recording them to CD as Audio files to play in a regular CD Player
I always make discs for my weddings with Intro songs, First Dance, Parent dance, ETC.. and searching for it in Virtual DJ is easy. Searching for them in Windows takes foreverrrrrrrr.
2nd part of the quesion what do you use for a good CD Ripper that will go above 128 for K/Sec???
Help thanks
Josh
Posted Fri 08 Sep 06 @ 5:00 pm
For the first question:
You could drag the songs in order in the playlist. You could save this playlist. Maybe it is possible to burn the songs of this playlist in Winamp, or Nero.
Second question
I use CdEx for ripping it is an easy to use application with the Lame encoder for proper quality. This is a freeware application that could be found here
Ewout
For me musicmatch has good quality and easy to rename tags.
www.musicmatch.com
