Forum: Old versions
Topic: bit rate problem (and 1 other question)
So,
I love vdj but I am having trouble with the rip vinyl. The computer won't let me select a bit rate for my songs. If I don't select a bit rate I can't record.
Also, when I have vdj running and I minimize it the screen goes black for a sec and then comes back. If I click on any icon or file the screen goes black. What is wrong? This has never happened before.
Anything help.
Thanks
Posted Tue 22 Aug 06 @ 6:18 am
abnormPRO InfinityMember since 2003
I am not sure about your first question, but the reason your screen goes blank is you probably had VDJ in full screen mode. Full screen (depending on the skin) is usually 1024X768 and if your desktop is set to anything else, your monitor takes time to change the resolution or refresh rate.
Posted Tue 22 Aug 06 @ 8:53 am
Ok,
Thanks that fixed the screen problem. I still don't know about recording though.
Posted Tue 22 Aug 06 @ 9:40 pm
