I just got me VDJ pro, hooked up the Maya usb to the tables but scratching using the timecoded vinyls sounds husky....just does not sound like they way i heard it soound for other users....What am i doing wrong??? Anyone Please help...
Posted Tue 22 Aug 06 @ 3:52 am
Hey dude try asking that question here http://www.virtualdj.com/forums/31/Hardware_Technical_Support.html
These folks can help you more than in the General Forum.
MS
MS
Posted Tue 22 Aug 06 @ 4:00 am
thanks bro...
Posted Tue 22 Aug 06 @ 4:18 am
DJplayboyUS
Welcome as the new Pro user!
Check in your settings of Maya to lower down the latency, if the latency is high (like in Hercules MK2) when you scratch hard sound messes up so it's maybe your problem? Oh, and Maya should work fine even if you scratch hard, it's better with TCV's than MK2.
Posted Tue 22 Aug 06 @ 7:10 am
