to stop pou ap oti vlepw katargithike,kai to beatmach kai play mazi pou eixan ta proigoumena,kata t alla einai pio grigoro,einai poly pio wraio to mayro xrwma,an vgei kai kapoio skin me tin vasiki ekdosi kai to skip beat tha einai super.
Posted Sat 02 Sep 06 @ 5:08 pm
to stop den katargithike aplos prostethikan cue/stop kai play/stutter , kai mporeis na xrisimopiiseis to palio skin 3.4
Pio skin xrisimopiieis tha sou kano ego tis allages..
Posted Sat 02 Sep 06 @ 5:18 pm
xrisimopoiw to virtual dj:internal mixer,evxaristw,toso evkolo einai na to ftiakseis?
Posted Sat 02 Sep 06 @ 5:28 pm
http://rapidshare.de/files/31696250/InternalMixer.xml.html
bale ayto to xml mesa sto virtualdj.zip (kanto backup prota)
sou allaksa ta pause kai play, kai ta pitch bent koumpakia ta ekana "skip_beat" 8 beat...
gia to sync pou den ksekinaei einai apo design...
Posted Sat 02 Sep 06 @ 5:46 pm
piga sta skins sto virtual dj.zip to evala mesa alla den vlepw kapoia diafora,mpas kai den kanw kati swsta?
Posted Sat 02 Sep 06 @ 6:00 pm
dokimases ta koumpia ? i allagi einai stis leitourgies mono, den allaksa to bmp ...
Posted Sat 02 Sep 06 @ 6:53 pm
to vrika,nai to cue egine stop alla ta pitch bent koumpakia den allaksan,den peirazei ap oti eida mporw na to valw shortcut to skip beat kai as min exei tetoia koumpakia,opote tha volevtw me ayta gia tin wra,thanks
Posted Sat 02 Sep 06 @ 7:03 pm
kai ta pittch bent douleyoun san skip_beat 8... mazi ta ekana...
kai to play_stutter egine play_pause
Posted Sat 02 Sep 06 @ 7:14 pm
Vdj 4.0 (history)
* new features:
o brand new audio engine
o new professional default skin
o greater pitch slider fluidity
o improved scratching sound
o turntable pitch and software pitch are better integrated
o video transitions can now be "activated". Some transitions will automatically crossfade when activated, while newer ones will put themselves in "smart mode", where the crossfader moves automatically to match what you're doing on the turntables. (see "default" transition)
o new synchronisation engine. Sync is now smoother, and samples are correctly beatlocked even on TCV
o browser icons can now be changed in skin
o plugin can display strings on the default interface (with declare_parameter)
o new plugin SDK for easier interfaces
o plugin stability improved (including VST)
o new plugins: VideoEffect/Text, SoundEffect/KeyChanger
o compatible with SSL crates (added only if fresh install)
o sound Plugins can now apply on: Song (as before), Mixer Line (like old scratch), or Master. (cf SDK)
o import of iTunes playlists on fresh install
o import of all SSL crates on fresh install
o compatibility with MSN's "what I'm listening to"
o songs with a BPM more than +/-10 from the actual bpm have a special icon in the browser (range can be change in registry "SimilarBpmRange")
o new video transition mode: click on the video preview to go from one deck to another (right click for temporary, double click for instantaneous). click on the transition button goes in smart mode
o latency can be set from config menu
o new option in TCV/TCCD: browser track (work without needing a new TCV)
o new skin possibilities (visual type="rotate", etc, check basic skin)
o compatibility with Numark iCDX units
o individual mastertempo on each deck (key lock)
o new "performance" optimization page in options
o new soundsetup page
o soundsetup automatically detects u46dj, maya, djconsole or dxm01usb cards with fast setup
o new video fx plugins: SlideShow, Camera, Sonique
o broadcast of titles fixed (can be disabled with "BroadcastShowTitles" in registry)
o clone_deck copies gain
o midi relative sliders
o native serato compatibility
o database scan no longer enter sensitive folders like "local settings" or "application data"
o compatible with 48Khz soundcards (ASIO and KS)
o new option: "autoheadphones"
o new performance option: "overclock"
o warning message if skin resolution unsupported
o new video option: load plugin when no video available
* new actions:
o new consistent effect/sample/video action names (old deprecated names still compatible for old skins, but no longer displayed)
o key_offset (will sound better when new HQ mastertempo is ready. Right now stay between +/-6 semitones)
o reverse
o delete_cue, play_stutter, pause_stop, select_loop, etc. (check full list in shortcuts)
* bug fixed:
o jumping further while the song is loading, or loading a new song, can't make the software to skip anymore
o fast rewind past begining crash corrected
o smartloop bug corrected
o plugin shortcut crash corrected
o small visuals glitches corrected (cues, sliders, vst, ...)
o ripdvd fixed
o bug in loading non "44Khz/16bit/stereo" WAV files fixed
o network synchronisation and multi-instance synchronisation fixed
* new features:
* new actions:
o reverse
* bug fixed:
o ripdvd fixed
Posted Mon 11 Sep 06 @ 2:43 pm
Ma kala akoma na bgaloun ti v.4 se demo ekdosi? Eleos
se 11 meres exo adeia, an mexri tote den exei bgei tote tha katafygo se pio drastika metra!
Dj dell etoimase ena krebataki spiti sou, tha ertho gia merikes meres na dokimaso ti 4!
Posted Mon 11 Sep 06 @ 4:03 pm
aledjo
H trial pou katebazeis einai i Ver 3.4 apo lathos leei Ver 4.0 sto site.
Mporeis mos na katebaseis edo
http://www.01net.com/telecharger/windows/Multimedia/lecteurs_audio_mp3_cd/fiches/28696.html
Pata ekei pou leei "telecharger''
Ok?
Ok?
Posted Tue 12 Sep 06 @ 11:53 am
καταρχην και εγω κατεβασα την εκδοση 4 και οντως στην προακουστικη εχει προβλημα!!το δοκιμασα σε 3 υπολογιστες και εμ ισαρυθμες καρτες ηχου και κανει ολο χρατς χρουτς σε βαθμο να θελεις να το σπασεις!κατα τα αλλα λυθηκε ενα πολυ βασικο πορβλημα που ειχαν οι αλλες εκδοσεις,οταν βαλεις ενα ολοκληρο σιντι στο playlist για να στο παιξει δεν αφηνει καθολου κενα μεταξυ τρακ αν ρυθμισεις οι αλαγες να γινονται με 0 sec καθυστερηση,παιζει μεγαλο ρολο ειδικα σε σιντι που ειναι συνεχομενα και λαιβ.πραγμα που οι παλιες εκδοσεις δεν υποστιριζαν αλλαγες sthn playlist me 0sec delay.
κατα τα αλλα δεν θα το χρησιμοποιησω ακομα μεχρι να δουμε τι θα γινει με αυτη την προακουστικη που ειναι χαλια.
εχιε κανει καμια ιδεα?
Posted Tue 12 Sep 06 @ 3:05 pm
djdad wrote :
aledjo
Ok?
Ok?
thanks! Estila to link se ena filo mou na to katebasei.
Kai mou kanei entyposi giati de to grafei sto site
http://download.virtualdj.com/virtualdj_trial.exe
Posted Tue 12 Sep 06 @ 4:31 pm
giati argei to download.com na kanei update kai to balan prosorina edo..
Posted Tue 12 Sep 06 @ 5:43 pm
Thelo to Dj 1000 v4!!!
Posted Wed 13 Sep 06 @ 1:01 am
Exo to 3.4 kai paizei roloi!!! Alla thelo to skin Pioneer Dj1000 v4!!!!!!!!
Posted Wed 13 Sep 06 @ 1:04 am
poli kalo to 4 poli kalitero apo to 3.4 mpravo stous kataskeuastes!!!
Posted Wed 13 Sep 06 @ 1:34 am
Kalispera se olous
Exo to exis provlima exo se 1 dyktyako pc ta mp3 moy kai ta trexo apo mapped drive.
otan loipon prospatho na ta trexo den moy deixnei ta filenames para mono to eikonidio kai tipote allo
sthn grammi toy mp3.dokimasa opoiodipote skin alla tipote. Kamia idea? i kamia rythmisi?
Tha eimoyn ypoxreos.
Posted Thu 14 Sep 06 @ 9:33 am
re alfa 156 mipos mporeis na mou peis pos ginetai na to kano na exei 0s delay sthn playlist??vazw to fade length sto 0s alla pali otan mpainei to allo yparxei ena keno...ta cd se alla programmata den exoun kena..
Posted Thu 14 Sep 06 @ 1:01 pm
θα βαλεις τις ρυθμισεις σε 0 sec kai force fade enable...
Posted Sat 16 Sep 06 @ 11:56 am
