Forum: Old versions
Topic: Karaoke Problem ... :-/
Hi guys. I am new in this I can't even call myself a "beginner" in this but I am still learnin'. See, I have a little problem with the Microphone. I'll explain... I try to make a mix and in the same time to rec my voice using the microphone (with what else...) and when I check...I don't hear my voice. It's like I've never turned that effect on. Can you explain to me how to make it right? Is something wrong with the current effect or my microphone is not pluged-in properly (although I've been replug-in it all night)... Thanks for the time :) Waitin' for your recommendations...
Posted Fri 21 Jul 06 @ 10:19 pm
xeonPRO InfinityModeratorMember since 2004
Be sure that your microphone works :) and that you have volume slider at windows mixer on.
Posted Fri 21 Jul 06 @ 11:36 pm
