Topic: DRM Help..
This may or may not help you, but something to keep an eye on. I do not use DRM files, so can not vouch for it. If you do, give it a try, and let others know.
http://hymn-project.org/jhymndoc/
Posted Wed 10 May 06 @ 6:49 pm
xeonPRO InfinityModeratorMember since 2004
niceeeee!
Posted Wed 10 May 06 @ 7:18 pm
DJ CyderPRO InfinityModeratorMember since 2003
Doesn't work with the new version of itunes, VDJ has "play for sure" technology in built. I tunes is a lost cause. Why try to beat it when you already have some drm support?
Posted Wed 10 May 06 @ 7:33 pm
djejPRO InfinityMember since 2004
This was a very helpful site for i-tunes. I used it a million times. Although unfortunately it no longer works with i-tunes as apple updated their DRM. Last I checked the jhymn forums they hadn't yet figured it out.
i was using a long before but forgot where i found it. now is not working anymore??
i tought i found now losted old good site.. grr :D
Posted Wed 10 May 06 @ 7:44 pm
As I stated, I do not use any DRM media, but know that others do. I don't understand why, but I will bet that there are thousands of DJs, that DO use I tunes. They said they were working on a fix for ver 6, that's why I said to keep an eye on it. So, I posted for those that might get some use out of it. I don't use TCV, but still look at the post, because I might learn something.
Posted Wed 10 May 06 @ 7:56 pm
