@ putte,
Hi, i like the look of your case, but there doesn't appear to be any padding in it, is everything bolted into the case somehow. I'd be very interested to know, I'm just putting together a case myself at the moment.
Thanks.
Andy.
Thanks.
Andy.
Posted Tue 18 Jul 06 @ 6:55 am
Hi everything is inside the case, under the hercules is the usb drive .under the laptop and mixer is the powersupplys .
Posted Tue 18 Jul 06 @ 11:58 am
asass
Posted Wed 19 Jul 06 @ 5:30 pm
Hey Tex, nice neat setup. Although it seems you would get blown through the wall with your sub firing right in your face. :) Seems a little cramped, but at least it is neat. :) I used to do everything on a desk like that at one point. If you have some extra cash (and the room) try ordering an 'L' desk from Officemax. They run about $120. It's worth it. If my studio had enough room I would have two of them right now.
Posted Wed 19 Jul 06 @ 8:40 pm
This is the newest addition to my setup!
http://www.simonelvins.com/paper_record.html
Quote :
To play the record the handle needs to be turned in a clockwise direction at a
steady 331/3 rpm. The paper cone then acts as a pick up and amplifies the sound
enough to make it audible.
Posted Thu 20 Jul 06 @ 12:44 am
Great setup Can't it be made so that it works with the heat from the Pizza inside. :-)
Posted Thu 20 Jul 06 @ 11:06 am
I will build a pair of them.
But, anyone has the interface to conect it to VDJ... (LOL)
(Have they a WI-FI inside: LOL)
Posted Wed 26 Jul 06 @ 12:53 pm
Posted Wed 26 Jul 06 @ 11:28 pm
Nice setup Mariush! Where are you from? :-)
Posted Fri 28 Jul 06 @ 2:19 am
Nice setup, but all those glasses with liquid would worry the hell out of me. :)
Posted Fri 28 Jul 06 @ 7:17 am
Hi. I'm from Romania. About glasses.....nothing bad happend....yet. :)
Posted Fri 28 Jul 06 @ 11:24 pm
Here's some pics of my decks that will eventually be used with virtual dj...
As you can see, not in the greatest shape at the moment, but they're coming along nicely. I also have a Technics DZ1200 and a CDJ800 (currently dodgy) to go with them too)
Posted Sat 29 Jul 06 @ 5:17 pm
Hi all,
here's my new case, it's just a 12u mixer case, but i've added the shelves for the laptop, dac3, fans, hard drive, etc :)
Posted Mon 31 Jul 06 @ 4:42 pm
@secretsoul: What the hell are you doing with your gear? Will you use it for timecoded vinyls? If you're good in electronics, you could add a rotary encoder and make a MIDI device with a MCU...
Posted Mon 31 Jul 06 @ 9:38 pm
basically it's a pair of technics i got that are simply battered. there's quite a few parts need replacing so i'm gonna restore them one at a time.
the 1200 isn't too bad (new tonearm, new pitch and that's all it needs) but the 1210 is very bad. i've had to completely dismantle it, taking all the electronics out of the casing, and it seems that it had a drink spilt on it at some point which has done a fair bit of damage. but i'll get there, eventually. it'll compliment my dz1200 and cdj800 nicely :D
Posted Tue 01 Aug 06 @ 12:24 pm
Fortunately the electronic board is neat and not in SMD... This will help you while "debugging". Maybe try by plugging it to the power supply and your nose will tell you where the problem is, if something was burning... If it's a sort of diode... it's a curse, as it's difficult to find. Maybe someone who knows electronics will help you.
Posted Tue 01 Aug 06 @ 2:56 pm
it's ok, i know the problems, i have some experience and qualifications in electronics. it's just a case of tracking down, ordering and waiting for the relevant parts. the target lamp was completely burnt out, it had even burnt the wires and the pcb under it, so that's been removed now. the main (and more costly problem) with the 1200 is the state of the chassis. the top is quite battered around the edges with heavy scratches and markings, and the rubber base isn't in the best condition either. unfortunately those are the most expensive parts to replace too.
Posted Tue 01 Aug 06 @ 3:02 pm
@secretsoul
If you need help i got a service manual for the 1200 somewhere and might be able to get one for the 1210 also. + i also know "some" about electronics ;-)
Posted Tue 01 Aug 06 @ 3:16 pm
pern wrote :
@secretsoul
thanks, i managed to download a pdf version so should be ok. btw, the 1200 and 1210 are the same decks ;)
Posted Tue 01 Aug 06 @ 3:57 pm
success, the 1200 is working almost perfectly. the new pitch control came this morning, as well as some cosmetic parts (on/off switch, pitch ornament, etc) and i fitted and tested my new ortofon nightclub s carts for the first time. the final steps are to replace to scratched, black 1210 tonearm that's on it for a nice new silver 1200 one, then change the dodgy audio leads for high quality ones and to swap all the LEDs and the target lamp for blue ones.
not looking forward to starting on the 1210 though, that's got much more cosmetic damage and is gonna take longer to get all the parts.
Posted Thu 03 Aug 06 @ 4:09 pm
