Hello again. I have a new registered MK2 console. I haven't been able to use the talk over feature. I think I'm following all the steps correctly but the Mic won't cooperate. I want to use the mic plug that's on the console, Can any1 help
Posted Sat 21 Jan 06 @ 7:23 pm
I have the same problem...
Posted Tue 11 Apr 06 @ 11:06 pm
Some people have the same problems, but first of all you have to check a program which is comming with DJConsole. In 1st edition of DJC you should in program (actually called DJC mixer) set to DJ mode. Don't know how it is in MK2 version because i don't have it, but check this first!
Then if when pushing talk over button sound of song goes lower, it works. Then it all depends of your mic if it works.
Posted Tue 11 Apr 06 @ 11:36 pm
click the herc mk2 icon in the taskbar...
then when u click ON the knob next to the microphone plug, the "on-air" should light up on that control panel.... if that works, then your software should be fine- check your audio connections to make sure speakers are working and microphone to see it's also in proper condition
Posted Wed 12 Apr 06 @ 2:10 am
