Can anyone tell me the diferences between this two versions apart form Audio HW config?
I've been using first one till now with old HDJC but have error problems with MK2
I own both of them and don't know which to use....i guess second one for the new MK2?
Posted Wed 28 Dec 05 @ 4:17 am
Posted Wed 28 Dec 05 @ 5:19 pm
@djkike
Use the full pro version when using the console. It has BETTER support for the console, and has a lot of features that the console version does not have.
The pro version will also have a console mapper really soon (Dj Cel's plugin)
Posted Thu 29 Dec 05 @ 3:20 pm
My VDJ crashes every session since i upgraed to 3.2 and changed to MK2...i thought it was some kind of incompatibility versions.
Posted Thu 29 Dec 05 @ 3:22 pm
did you update the drives and firmware for MK2?
there is an Virtual DJ 3.2 update at www.hercules.com
And if MK2 keeps crashing, I would try a reinstall... might be some driver issues
MK2 works flawless with me :)
Posted Thu 29 Dec 05 @ 3:35 pm
i've also reinstalled the console as well as VDJ. Believe me i've tried lot of things. Maybe my notebook has turned crazy and decided to disturb me.... :( But i know i have no virus, spyware or trojan afecting and the registry is correct as far as i can see.
Posted Thu 29 Dec 05 @ 11:09 pm
