hellp instal
Posted Tue 23 May 06 @ 7:20 pm
@mavic what do you need to instal? where do you have problems?
Posted Tue 23 May 06 @ 9:27 pm
@mavic:
DEMO DOWNLOAD: http://www.virtualdj.com/download.html
If you have HERCULES for VDJ, fill your serial here: http://www.virtualdj.com/fusers/modifuser.html
Posted Thu 25 May 06 @ 2:31 pm
Visit my website: www.vgfuture.it
Thank's to all, bye bye VGFuture
Posted Sat 03 Jun 06 @ 2:26 am
Hello I am new on the site, I use VDJ and atomix since 2001 or more :P
What I have to do to get the new effects (isolator, jetlag... ) ???
Posted Sun 18 Jun 06 @ 11:18 am
I think you should upgrade your VDJ to PRO and you will get access to all effects.
http://www.virtualdj.com/purchase
Posted Sun 18 Jun 06 @ 12:21 pm
cuanto vale¿¿¿¿¿
Posted Sun 18 Jun 06 @ 4:15 pm
mavic wrote :
hellp instal
Seriously, I feel SOOOO bad that I can't stop laughing at this.
I'm in tears and can barely breathe.
I vote THAT to be the "Most Desperate Call For Help" post of ALL TIME!!!
... hellp stop lafing ...
Posted Fri 23 Jun 06 @ 10:41 am
Yes, you need to have PRO
Then you can acces here: http://www.virtualdj.com/addons/effects.html
You can buy cheaper 'cos you're home edition user: check here
Posted Wed 05 Jul 06 @ 2:30 pm
dj deivis wrote :
cuanto vale¿¿¿¿¿
English: How much is it?
@dj deivis:
Existe un apartado en CASTELLANO en el FORO: PULSA AQUI
Donde puedes exponer tus consultas en castellano.
Además. los precios los puedes ver aqui
English: You can go to the SPANISH FORUM, and ask in spanish.
Also, you can check price at purchase section
Posted Wed 05 Jul 06 @ 2:35 pm
I also downloaded the new drivers, and now i can't scratch with my Jog wheels. They are WAY SLOW! I have the original Hercules DJ Controller.
I have checked in the settings and i've selected to scratch with job wheels and with the stick. Neither work. They only change the tempo, as if those two options werent' selected.
I thought too that it had to do with scaling, but could not find place that would scale it in addons dialogue.
I downloaded the "DJC Mapper v3.0" cause it looked like the most full featured DJC Mapper available. I should I try "Mapper for DJC mk2" instead?
Thanx for your help.
Rik
Rik
Posted Fri 21 Jul 06 @ 10:01 am
@Euphoria: you can downaloda any ampper for DJ Consoles, as they're all compatible.
Posted Wed 16 Aug 06 @ 7:41 pm
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Posted Mon 28 Aug 06 @ 6:02 pm
ok
Posted Mon 28 Aug 06 @ 6:03 pm
s
s
s
ss
s
s
s
s
s
s
ss
s
s
s
s
I went to Hercules website, but they still have the same drivers they had back in Jan 2006 for version 3.2 and 3.3. Am I missing something because I would like to upgrade my drivers for VDJ 3.4?
Posted Mon 04 Sep 06 @ 5:38 pm
The driver update you mention works for 3.4 and 4.0 too :)
Posted Mon 04 Sep 06 @ 7:10 pm
so basically i dont need to update??...coz i already have that...
cheers
DJ Rudra
cheers
DJ Rudra
Posted Tue 05 Sep 06 @ 3:51 am
Is it worth to install the new drivers? , because i see a lot of complains about them...
I want to know if its ok to install them?¿?¿
Or if its better with the one that came with it?¿?
Posted Tue 12 Sep 06 @ 9:11 pm
For any 3.2 - 3.3 - 3.4 & 4.0 version of virtual DJ (DJ console edition & Full edition) this is the correct driver for Hercules DJ console models MK1 & MK2 ftp://ftp.hercules.com/pub/webupdate/DJMk2/2006_CMK2_1.exe
& this is for DJ console MP3 ftp://ftp.hercules.com/pub/webupdate/DJMP3/2006_CMP3_1.exe released on JANUARY 20th 2006
Posted Tue 12 Sep 06 @ 9:18 pm
