Forum: VirtualDJ Skins
Topic: !!! advanged default !!! - Page: 2
djjbPRO InfinityMember since 2004
bellow the automix-button is a pannel-button. normal or console..
i hope this works.
Posted Tue 20 Dec 05 @ 11:51 am
ciocePRO InfinityMember since 2004
Make Attention because the automix button have two different function with left click (automix now) or right click (automix stay on and load track from playlist), I think you can insert onle little long orizontal button (name normal or console) in the middle down of FX and up to the automix botton with the same length.
Thanks a lot, I can only wait the update of your fantastic skin.
Bye ;-)
Ps I like DJ John crazy modify .-))))
Posted Tue 20 Dec 05 @ 11:56 am
Posted Tue 20 Dec 05 @ 12:17 pm
Posted Tue 20 Dec 05 @ 4:04 pm
Very nice work!!!
Posted Tue 20 Dec 05 @ 4:19 pm
that's good to read..
i'm happy..
Posted Tue 20 Dec 05 @ 7:53 pm
HaywardPRO InfinityMember since 2005
John,
I'm glad you got the updates done. Looks good.
I cannot find the update on the SKIN menu, is it there?
Posted Tue 20 Dec 05 @ 8:52 pm
not yet...i'm trying it out now. searchin' for bugs..
Posted Wed 21 Dec 05 @ 2:33 pm
Posted Fri 23 Dec 05 @ 12:53 pm
still not updated..!?
posted again today.
Posted Fri 30 Dec 05 @ 6:00 am
djcelPRO InfinityModeratorMember since 2004
Don't worry the team have all your last uploaded versions so just wait
Posted Fri 30 Dec 05 @ 9:27 pm
skin activated
Posted Mon 02 Jan 06 @ 3:45 pm
Thanks Djjb for the update of the skin.
Can you explain me what is the function of MT = ON or OFF near the minimize button?
Posted Tue 03 Jan 06 @ 11:10 pm
MT is master tempo
Posted Wed 04 Jan 06 @ 9:18 am
i changed the collors and the "select" - buttons
it's in my blog.
Posted Sat 07 Jan 06 @ 8:57 am
Black is a good idea.
I see the tooltip "show remixing commands" on the console FX setting in the panel for the setup of the skin, is this a bug? But in any case this work fine.
Can you please insert the MIC level bar?
I think the time to start and to end font is little small, do you think it's possible to use the BOLD in the font?
Posted Sat 07 Jan 06 @ 2:18 pm
i see what i can do...
Posted Sun 08 Jan 06 @ 5:48 am
Posted Sun 08 Jan 06 @ 8:42 am
I see you have ACTIVE for the deck currently playing and DEFAULT for the other deck, maybe you should change DEFAULT to read HEADPHONES or MONITOR??
This may be more useful to new users of VDJ.
Posted Wed 11 Jan 06 @ 9:45 pm
it's the same as the original default skin , isn't it ?....
Posted Thu 12 Jan 06 @ 8:33 am
68%
