Forum: Old versions
Topic: DirectX Issues!! Please Help!
Rory05PRO InfinityMember since 2005
Hi,
Just got my Hercules Console yesterday and I'm having some problems!! When I set it to ASIO it won't let me open VDJ, it says that theres a directX problem!! And if I open it the other way (advanced mode) the same music comes out my speakers an my headphones!!
Someone PLEASE help me!!!
Thanks,
Rory
Posted Sat 08 Oct 05 @ 2:30 pm
Doesnt matter. I got it sorted.
Posted Sat 08 Oct 05 @ 11:30 pm
claxPRO InfinityMember since 2004
Could you explain the solution ? It could be usefull for other users. Thanks in advance.
Posted Tue 11 Oct 05 @ 5:46 am
The console version of VDJ supports only DirectX sound output. He put his dj console in the asio mode, therefore VirtualDJ complained that it cannot use DirectX soundcard.
So you have to be sure that you have console set only to DJ mode, with ASIO disabled when using Hercules bundled 1.09 version of VirtualDJ.
And also, there's a button under the hecules mixer sound controls that allows you to select what channel you want to listen in headphones, he had it switched to the MAIN instead of MONITOR.
Posted Tue 11 Oct 05 @ 2:48 pm
