Forum: Old versions
Topic: Static / crackling noise with 2.1
ShaggyTHome userMember since 2001
I have a laptop (p3 500; 256ram) running winxp pro with the new M-Audio Sonica Theater USB sound card.
I get what sounds like crackling, but may be the notorious skipping problem everyone is spraying about.
What DMA settings are reccomended for the hard drive, is hardware acceleration an issue, and are there any other remedies for avoiding these problems?
Posted Tue 11 Mar 03 @ 10:26 pm
HomeboyPRO InfinitySupport ManagerMember since 2003
If you are using 2.1 upgrade to 2.2
Posted Wed 12 Mar 03 @ 1:50 am
Will upgrading improve this problem, specifically?
Posted Wed 12 Mar 03 @ 6:56 pm
Not for sure but possibly. Upgrade and we will find out :)
Posted Thu 13 Mar 03 @ 10:28 am
GrimmPRO InfinityMember since 2003
I will also suggest, if upgrading doesn't solve the problem, to play around with the hardware acceleration.
Grimm
Posted Thu 13 Mar 03 @ 11:12 am
Upgrading seemed to improve the problem. I'm psyched!!
I've used traktor dj studio 2, and it's got some great features, most notably midi control capability. But, alas, Atomix is easier, more intuative, and comfortable to use. I prefer it. I just hope they continue to incorporate features of other software...
Posted Sat 15 Mar 03 @ 1:17 am
