Topic: Swap Live/Headphone Front/Rear Channels on 3D Soundcard
tboudrePRO InfinityMember since 2003
Firstly, I wouldn't have to ask this question if my INCA88 sound board worked properly an reliably. But, in the absence of that, I use my onboard sound of my ASUS P4C800 Deluxe to DJ until either Audiotrak or ASUS can solve the sound board problem. It is a SoundMax chip configured for front and rear speakers. The front channel has powered output that can drive speakers or headphones. The rear channel is only line level output. In Virtual DJ, when you set up the 3D sound card the main (live) output goes the front speakers. The headphone monitor goes to the rear speakers. This requires me to use a headphone amplifier for the monitor. If I could swap the front/rear outputs in Virtual DJ, I could plug my headphones into the powered front channel and not use the headphone amplifier and plug the main output into the rear channel to the amps and the live sound. It would be great if you could put a button on the sound configuration screen that I could check to swap front and rear channels.
Thank You,
Troy a.k.a
Posted Sun 25 Jan 04 @ 5:52 pm
