Is it possible to use a microphone to talk during broadcast mixes???
if yes? How?
if yes? How?
Posted Sat 15 Jun 02 @ 12:54 pm
yes i think so! you can put a pc microphone into your "mic" input on your soundcard and in the brodcasting plugin there is a microphone option and there is a button "push to talk" press that to speak or you can do it through your mixer!
Posted Sat 15 Jun 02 @ 4:51 pm
thanks I'm gonna try it out!
Posted Sat 15 Jun 02 @ 6:30 pm
Doesn't work... when I press the "TALK" button, people don't hear me, or not loud enough to hear what I'm saying... i checked my volume settings, and I noticed that when I press the "TALK" button, in my mixer panel the "MONO IN" setting automatically will be put to minimum level
do you know what's wrong? I tried every setting I could
Posted Sat 15 Jun 02 @ 7:24 pm
i think in the "input" tab on the plugin you need to click "open mixer" and make sure you have "microphone" checked ok if it doesnt work get back to me!
Posted Sun 16 Jun 02 @ 12:36 am
I saw an lengthy and very informative post about this on the technical supportforum over at shoutcast.com, pasting it in here would be a mess but just have a look over there and you'll probably find it
Posted Mon 17 Jun 02 @ 9:03 am
