Forum: Old versions
Topic: Mids and Highs Distorted...Why????
I just purchased and downloaded Atomixmp3 a couple days ago. This has to be the best program I have used so far. Just one problem...Why do the mids and highs sound somewhat distorted? They sound great on other players. Is this a problem with the software? Has anyone else experienced this? Any suggestions are appreciated.
Pentium III at 933mhz
Windows XP
384 mb
Guillemot Maxisound Fortissimo
Posted Thu 03 Jan 02 @ 10:34 pm
mamaPRO InfinityMember since 2003
Try to install the latest drivers, the latest DirectX and disable "master tempo" in the sound config.
Posted Thu 03 Jan 02 @ 11:33 pm
(nt = no text)
Posted Fri 04 Jan 02 @ 6:16 am
Thanks for replying. But I couldn't find any option to disable the "master tempo" under the sound configuration options. Am I missing something? Also, I have Windows XP as my OS and this comes with Direct X 8.1, so my drivers should be up to date. Any other suggestions?
Philip
Posted Fri 04 Jan 02 @ 6:18 am
alreaHome userMember since 2003
In Atomix, go to Options, then click on Master Tempo!
Hope it helps, Adrien
Posted Fri 04 Jan 02 @ 12:26 pm
Sorry, options, not sound config! :-)
Posted Fri 04 Jan 02 @ 6:27 pm
I am sorry, I am must be missing something or have a different version. Under the Options menu, I cannot find anything that says "Master Tempo." I see lots of other stuff, but not this.
Posted Fri 04 Jan 02 @ 7:06 pm
Discribe what you see please, it woul help.
Adrien
Posted Fri 04 Jan 02 @ 8:27 pm
If it isn't Master Tempo, try finding Time Scretch. Sorry for my orthography.
Posted Fri 04 Jan 02 @ 9:53 pm
Ok, this is what I see:
Time Stretch: Enabled
Pitch Range: -34% to 34%
Crossfader: Full
Security: Ask
Tooltip: Enabled
Muliti instance: Disabled
Auto BPM: Enabled
Auto Beatmatch: Enabled
Auto Gain: Enabled
Auto Pitch-Reset: Enabled
Mix Length: 10s
Sound Configuration...
Change Skin...
Select Visual...
Shortcuts...
History...
Posted Sat 05 Jan 02 @ 1:33 am
ok so Master Tempo = Time strench. Try without.
Adrien
Posted Sat 05 Jan 02 @ 1:56 am
DJ RickPRO InfinityMember since 2003
or try the 8% instead of 34% pitch adjust. I use the time stretch, and have never noticed any problems with the sound. But if I need to adjust more than 8% I either pick another song, or don't mix it. It'd be cool of we had a step or 2 in between 8% and 34%... like 16% would be nice. I don't think I'd go for a mix that needed the whole 16%, but it'd be nice to have a smaller option than 34%. Just a thought.
Posted Sat 05 Jan 02 @ 7:45 am
