I was looking but I couldn’t find it, I have a launchpad midi, and I’m looking for the script on how to change the led colors
Posted Mon 21 Apr 25 @ 11:14 pm
colours manually selected with color
to blend between 2 colours determined by a value color_mix
Other things you can grab to set a hardware colour dynamically
cue_color loop_color get_deck_color get_loaded_song_color get_browsed_song_color get_sampler_color sampler_color get_key_color
Posted Tue 22 Apr 25 @ 12:13 am
Do I have to put a formula in there or the color name, what they have is 00FF00, something like that
Posted Tue 22 Apr 25 @ 12:23 am
Yes, either a recognised colour name or a colour in RGB hex format like you listed
example
color '#FF7F00'
hex format here is
FF red [so hex to decimal is 255, full strength]
7F green [127, half strength]
00 blue [no blue element]
example
color '#FF7F00'
hex format here is
Posted Tue 22 Apr 25 @ 12:32 am
Thank you
Posted Tue 22 Apr 25 @ 12:46 am
var '$padmode' 0 ? get_sample_color 46 : var '$padmode' 1 ? deck right slicer 6 ? get_constant '#00FF00' : get_constant '#AAFF00' : nothing.
This is the script for my launch pad mini, I'm trying to get just the sample LED to turn red instead of yellow, how can i do that?
Posted Tue 22 Apr 25 @ 10:37 pm
is what we had before color was a verb.
Change stuff, see what happens.
Posted Tue 22 Apr 25 @ 11:00 pm
In "Sampler" mode, your controller should read the color of the samples.
So, your button is yellow because the sample is yellow.
That's what the get_sample_color 46 part of the code does.
You "can" replace it to have a fixed color, but it's not recommended.
Posted Tue 22 Apr 25 @ 11:01 pm
