I have just installed the Remote app on Iphone 16 plus IOS 18.2 (December 22, 2024).
I cannot connect to VDJ V2025-m b8472 on Mac Sequoia 15.2
Remote is activated in VDJ - firewalls and blockers are turned off
The app only shows the message: Waiting for VDJ connection...
IP address matches VDJ
Any ideas ?
Any ideas ?
Posted Sun 22 Dec 24 @ 1:58 pm
Which did you start first - VDJ or the app? Try the other way around.
Posted Sun 22 Dec 24 @ 2:07 pm
Tried all scenarios - no luck
Posted Sun 22 Dec 24 @ 3:04 pm
Are you able to start a mobile hotspot on your phone? If so, what happens if you connect your main VirtualDJ machine and your iPad to the phone's hotspot and try the connection then?
Posted Sun 22 Dec 24 @ 4:03 pm
Same problem with Hot Spot via iPhone "Waiting for connection"
What are you paying 10€ for if the app doesn't work??
There is also no indication that it won't work with the current versions on Mac or iPhone - that is very annoying
Posted Thu 26 Dec 24 @ 12:34 pm
I'm able to connect successfully to my MacBook from the Controllers tab (it's not an automatic process initially, you have to explicitly connect it the first time).
I'm running the latest Remote version on Android and latest VirtualDJ EA version 2025-m b 8490 on MacOS Sonoma at the time of this writing on my home network and phone hotspot (also Android). It worked with the latest stable version, b8472 as well.
Posted Thu 26 Dec 24 @ 12:51 pm
Thank you very much - that was the right tip.
I didn't know that you had to select the remote separately in the controller menu - now it works.
Posted Thu 26 Dec 24 @ 1:48 pm
Holli-HH wrote :
I didn't know
https://www.virtualdj.com/manuals/virtualdj/vdjremote/remotesetup.html
Posted Thu 26 Dec 24 @ 1:51 pm
