Just updated to the VDJ 2025 early release and you are now not able to use both Shaders and Slideshow at the same time when mixing video. This was a great feature while using the Video Overlay of Broadcaster GFX. Instead of the static background you could have the slideshow playing, while you had the shaders activated. Please fix this, thanks!
Posted Sun 01 Dec 24 @ 5:24 am
Works fine here. Maybe you selected them as video source for audio only instead of video overlay?
Posted Sun 01 Dec 24 @ 5:43 am
no, tried it with both video and mp3 tracks. Also just 4 days ago a live video twitch stream I did it worked wonders. If I select shaders and then slideshow...it deselects shaders...and viceversa.
Posted Sun 01 Dec 24 @ 6:28 am
Can you post a screenshot of where you tried to select it?
Posted Sun 01 Dec 24 @ 7:07 am
Adion wrote :
issue has been fixed with the latest update, it seems to have been a bug that the devs ironed out, thanks!Can you post a screenshot of where you tried to select it?
Posted Tue 29 Apr 25 @ 2:38 am
