I have the following problem: I use a Pioneer FLX10. It's about the LED of the Slip Mode button. I have set the button so that vinyl mode is activated when I press the button without Shift and slip mode is activated when I press Shift and the slip mode button. Now when I activate vinyl mode, I want the LED of the slip mode button to light up, but that's not working at the moment. Please help.
Posted Sun 13 Oct 24 @ 5:54 pm
You need to remap LED_SLIP and LED_SHIFT_SLIP (or SHIFT_LED_SLIP) keys as well
Posted Mon 14 Oct 24 @ 6:10 am
Just delete the action assigned to LED_SLIP and you should be fine
Posted Mon 14 Oct 24 @ 3:03 pm
I will try and report :)
Posted Mon 14 Oct 24 @ 9:31 pm
That solved the problem, thank you
Posted Tue 15 Oct 24 @ 7:54 am
Hi, I have the same idea (problem) but no knowledge how to remap it.
Slip I don't use, Vinyl mode yes.
Could you post here what are the values you set for each key so that it works?
Posted Tue 15 Oct 24 @ 11:26 am
That works
That works
Posted Thu 31 Oct 24 @ 7:34 pm
