Topic: SKIN ENGINE: doesn't work
I'm making a skin and want to use a clipmask to hide part of the <visual> to make a VU, but when I use color inside a visual, it doest work.
This code, doesn't work, the clipmask is not aplied
<visual source="get_level_left" type="linear" orientation="vertical">
<pos x="+1" y="+0"/>
<size width="88" height="411"/>
<down color="red" />
<clipmask x="438" y="309" />
</visual>
But this works:
<down x="438" y="725"/>
</visual>
I have to put an image in the png to make the clipmask work. I also tried with <mask>, but it doesn't work
Posted Thu 22 Aug 24 @ 10:26 pm
Clipmask should be a BLACK AND WHITE image. It seems not in your case.
As for PNG, yes, clipmask can be avoided in a lot of cases if you use transparent graphics.
Posted Fri 23 Aug 24 @ 7:46 am
This is how my clipmask is on my png file. it works when I change the code to use a solid blue rectangle in png, but with vector graphics, it doesnt work
and sorry for the tittle of this topic, I put <clipmask> on the tittle but it seems that the forum doesnt allowed.
Posted Fri 23 Aug 24 @ 4:07 pm
Can I ask you to please test it? My mask is in Black and White
Posted Thu 29 Aug 24 @ 10:41 pm
AdionPRO InfinityCTOMember since 2006
clip mask indeed only works for images.
Do you actually need the clip mask though?
You could also draw the rounded border on top of the vu?
Posted Fri 30 Aug 24 @ 5:13 am
The skin that I designed has the VU meter around the channel and I want to represent the LEF and RIGHT vu accordingly and want to avoid png graphics, the entire skin is 99% vector based.
Posted Fri 30 Aug 24 @ 7:45 pm
