Quick script question. What is the best way to query the color of a hotcue?
Wish to set the color of a LED pad (w the LED Mapping script) based on the color of the hotcue.
(the hotcue can have different colors depending on its POI action)
have tried things like:
cue_color 29 'red' ? color 'red" : ....
color `cue_color 29`
color `cue_color 29 & param_cast 'text'`
color `cue_color 29 & param_cast 'hex'`
color `cue_color 29 & param_cast`
what's missing ?
help ?
what's missing ?
help ?
Posted Mon 01 Jul 24 @ 10:29 pm
Solved:
works
cue_color 29 & param_cast 'text' & color
works
Posted Mon 01 Jul 24 @ 10:38 pm
cue_color 29 already returns a color, so not sure why you need the two casts
Posted Tue 02 Jul 24 @ 4:54 am
Yesssss .. was over complicating it ..
Very simply :)
Thanks
you Rock !!
Very simply :)
Thanks
you Rock !!
Posted Tue 02 Jul 24 @ 5:42 am
