Topic: stems+fx echo out issue
hello dj's
I'm tearing my hair out over an issue.
I use stems+fx pad mode
I customized my pads this way for each deck
Pad 1: stem_pad 'Vocal'
Pad 2: stem_pad 'Instru'
Pad 3: stem_pad 'Bass'
Pad 4: stem_pad 'Rhythm'
Pad 5: padfx “echo out” 80% 1bt “stemfx:Vocal”
Pad 6: padfx “echo out” 80% 1bt “stemfx:Instru”
Pad 7: padfx “echo out” 80% 1bt “stemfx:Bass”
Pad 8: padfx “echo out” 80% 1bt “stemfx:Rhythm”
Usually it works very well but since last night for some reason the echo out effect on pads 5 and 6 no longer works as it did originally, it stops much faster than on pads 7 and 8 while the parameters of the scipt have not changed and are entered exactly as I indicated them above.
With this setting on stems+fx mode with a value of 80% the echo out effect extends over almost 32 beats before disappearing, which is always the case on pads 7 and 8.
But on pads 5 and 6 the effect is barely audible and disappears in less than 4 beats
I absolutely don't understand what could happen so that only pads 5 and 6 are affected while it works very well on the others with the same script
Does anyone have any ideas to help me fix this ?
Perhaps I could have accidentally activated or deactivated a function somewhere in the software?
Posted Mon 03 Jun 24 @ 1:25 pm
djmrkePRO InfinityMember since 2011
Watching +! same issue
Posted Tue 18 Jun 24 @ 11:27 pm
Fill the full param list for the padfx when calling or inspect effect_show_gui %STEMSLOT %EFFECTNAME
Posted Tue 18 Jun 24 @ 11:52 pm
