Hi guys,
I had put a lot of work into using Tag comments to categorise my library. When I moved that drive to a different machine, the comments were missing, so are they in the database not written to the ID3 tag?
I copied across the MyLists and playlists.
Cheers
M
Cheers
M
Posted Wed 15 May 24 @ 2:08 pm
read about setTagsAuto
https://www.virtualdj.com/manuals/virtualdj/appendix/optionslist.html
Posted Wed 15 May 24 @ 2:47 pm
Thank you,
Can you explain that a bit? What does it mean by "when something changed in VDJ? Like what? Is it very vague of or am I dense on this?
Posted Thu 16 May 24 @ 11:10 am
You said you're using tag comments, so presumably you're adding those comments via the VDJ tag editor.
The option automatically writes any changes you make (via the VDJ tag editor) to the tag in the actual file.
Posted Thu 16 May 24 @ 12:45 pm
Perfect thank you!
M
Posted Fri 17 May 24 @ 10:09 am
