Ive been messing around trying to make scripts that will fade the vocal in and out. Ive been able to create my own that doesnt always work as intended, but i found this script below that i can use to echo out the vocal which is a good start. Right now this effect (from vocal fx ) echos out the vocal while held down. How would I modify this to work with a single click?
down ? on & set 'VoxFXcount' `var 'VoxFXcount' ? get_var "VoxFXcount" & param_add 1 : get_text '1' & param_cast val` & effect_stems 'vocal' on & padfx 'echo' 0.75 0.5 0.25 0.65 'Mute Source:on' : off & effect_active 'echo' off & get_var "VoxFXcount" & param_equal 1 ? effect_stems 'vocal' off & set 'VoxFXcount' `get_var "VoxFXcount" & param_add -1` : set 'VoxFXcount' `get_var "VoxFXcount" & param_add -1`
Posted Wed 08 May 24 @ 10:02 pm
first off, good going on messing around, it's how I learnt, I messed around so much that I learnt every way not to do something until I figured out the only way left was how to to it.
But you've got a host logical/syntax errors, [I get it, you're experimenting] I can't quite figure out exactly your intention, [ not sure what "VoxFXcount" is used for]
Try this
Try this
padfx 'echo' 0.75 0.5 0.25 0.65 'Mute Source:on' 'stemfx:vocal'
Posted Wed 08 May 24 @ 10:39 pm
