Hello,
I am having some issues after upgrading to the new version.
I have some .cbz files on my PC that are for some reason showing up in my library. Not only is '.cbz' not in my fileFormats list - the cbz files are located on a drive that contains no music, and is in my ignoreDrives list.
Do i need to delete all VDJ folders from the extra drive or something?
Is there some special way i need to remove things from my library so the ignoreDrives setting takes effect?
Thanks
Thanks
Posted Mon 08 Apr 24 @ 2:17 am
You mean they come up when searching? When you check the tag editor, the extension is actually cbz?
Posted Mon 08 Apr 24 @ 8:27 am
I managed to get the files removed from my library by doing a "Remove from Search DB" operation on them.
I think I figured out my crashing issue... apparently I had enabled recursion on my library, which apparently has ~288,000 files in it (maybe 18,000 of which are audio). Any time I click my library with recurse on the program hangs for a long time.
I'm fairly sure this is how the .cbz files were added in the first place (although again id be concerned that the fileFormats filter isn't working).
I have tried re-enabling recursion again, and it seems that the .cbz files are not being re-added now. I didn't change the fileFormats, and I don't have anything in ignoreDrives. Not sure why the functionality changed, not that it's a bad thing.
It seems that enabling recursion also re-added a ton of online music to my library that i had previously deleted - im assuming it was coming from my history. Is there any way to avoid this?
Thanks for the help :)
Posted Mon 08 Apr 24 @ 5:17 pm
