I am using the grouping field and the comment one in order to add some information that will be useful for DJing on each track. I am seperating the info with ; just like I do for the genre field so that I can group by and get the filter grouped. However, it is not behaving ending with the same result.
Can you check if you can apply the same behavior of genre on these 2 fields: Grouping and Comment.
Posted Sat 06 Apr 24 @ 6:16 am
you should use the User1 field instead of the Comment field.
In addition to being groupable in filters, they're much more easy to quickly set/see in the info panel.
Posted Sat 06 Apr 24 @ 7:08 am
